EPeterman's avatar
EPeterman
fuse location
i HAVE A 2000 Discovery mod 37V, I have no 12V to the cigar lighter. It is located on the floor between the driver and co-pilot. I have traced the wires to the fire wall and there are no fuses present. The wires are heavy guage and protected by a plastic corrugated conduitand heads for the rear of coach. where oh where is the fuses??
  • It could be a bad ground also. It also could use a relay instead of a fuse.
  • So this is your third post on the same topic over the last few days. Both previous posts have responses. Have you looked at those? You really shouldn't start a new topic every couple of days asking the same question...
    Here's one...
    And the other...
  • Have you checked DC fuse panel on the end of the bed? Next to the AC circuit breakers.
    There is on some a fuse block adjacent to the gas pedal.
