10forty2 wrote:
Yep... I'd lean towards the house battery(s) being weak or dead. Check the voltage with a meter on them when you would think they were fully charged and if you don't have 12.5VDC or better, then you probably have a bad battery. And if you put a load on them when fully charged and the voltage drops significantly, they are not able to hold the charge anymore. If that checks out okay, then start tracing wires.
lean towards batterys being weak or dead?? LOL;; he told you the voltages are like 2.15 volts;; so no leaning here they are stone dead
