supercub's avatar
supercub
Genturi mount question?
Looking for ideas on how to support a Genturi to the side of the motorhome? I don't want to drill holes and screw a mount into the side of my motorhome. The Genturi goes by a window and I was thinking some suction cups on the glass, what do you thing? Open to suggestions. Thanks
Brian
  • I use the little square hook brackets that ome with it. The sticky back seems to work fine.
    Jim
  • I've seen several Genturi installations that use heavy-duty double suction cups with a release handle (similar to what glass installers use), one near the bottom of the pipe and another about as far up as you can comfortably reach. The Genturi pipe is fastened to the suction cup holder with its normal hardware.
    As long as the paint surface is fairly clean, they seem to hold quite well.
  • My Genturi came with double sided tape to stick the little square widgets onto the side of the RV. Worked just fine.
