hypoxia
May 03, 2015Explorer
katoomer wrote:
I'm a cabinetmaker by profession for over 40 yrs. I'm a certified fabricator for similar solid surface materials.
Just be sure to pre-drill all your holes with proper sized drill bits. Use PL Premium or other
similar construction adhesives to adhere to other materials. Being sure to rough up any areas where you want adhesives to adhere to. If you were bonding 2 pcs of Corian then you will need a specialized adhesive for Corian. Make sure to ease all edges as it is prone to chipping easily. It can be somewhat brittle and does not like to be twisted or flexed. Follow basic woodworking practices and you will be ok.
X3
I have noticed it seems to get more brittle with age especially if exposed to heat, like most plastic does.
