shaneperch
May 06, 2013Explorer
Got my Holiday Rambler home at my house. Jack problem
I got my HR home from my friend's house. I noticed that the jack light was on. but the jack is up. The light shows left rear is down, it is up and the light still is on. Also found where the Motor Generator is wired. it is wired into the house batteries and they are shot. So hopefully if I get new ones, that motor generator will work. I tried a vacuum cleaner plugged into it directly, didn't come on. I traced the wiring to the house batteries which has bad connections and the post is stripped so I can't tighten the wires. I think it will fire up once it has good power. Made it home without a problem. I went through the paperwork and the guy did a lot of maintenance. He replaced the engine with a crate engine. Weird.
