deprived
Oct 14, 2016Explorer
I just saw this post.
I've replaced my 2007 front-end before and it was, in terms of the front sway-bar, relatively easy. But I had a 2007 and the two bolts on the 2007 sway bar are fairly small and have low foot-pound specs. The newer sway-bar has a spec of 110 ft-lbs on the front-most sway-bar bolt, if I recall correctly. And it is a pretty big bolt.
I can't say for sure what specific problems the OP is dealing with, but if that factory bolt is at spec, then it just needs some muscle.
38,763 PostsLatest Activity: Dec 05, 2025
