Sam_Spade
Apr 26, 2017Explorer
bbqandbeer wrote:
I still need to figure out though why my shore power doesn't charge the house battery. I have another post about that, but I checked when I put the new battery in, and I'm not getting a charge when on shore power, ONLY when the alternator is running...
First be sure that your house battery disconnect switch is not in the OFF position.
After that you need a multi-meter to check, for instance, to see if you are getting 110 V AC at the input of the converter/charger. If yes, and there is no 12 V output, then the converter or a fuse in/on it has blown or the converter has gone bad.
38,776 PostsLatest Activity: May 14, 2026
