want-a-be's avatar
want-a-be
HD View 360 Antenna System
We have a HD antenna model HDMS9100 that is giving us a ER code, we have check what the manual says to do but we still get the code. It started out that the antenna would not turn are pick up any stations and was stuck on 7, I unplugged it and plugged it back in and that's when we got the ER code. The unit has power but will do nothing.
Thanks for any comments!
  • want-a-be wrote:
    dougrainer wrote:
    Once that model fails it is almost impossible to fix it. It has been discontinued by the Maker and even Tiffin does not have them. You can update to what Tiffin is currently using which is a much better Omnidirectional antenna. It auto scans 360 degrees instead of having to manually rotate with the wall remote. Doug
    Do you have more information on the antenna you are referring to?
    Model number and can it be hook up with the existing wiring!
    Thanks
    Sonny
    Not at home. Call Tiffin and they will tell you the current brand/model. You use the existing Coax and control wires. If you take the old apart you wiull probably find it is rusted out from water intrusion. Doug
    Thanks
    Sonny
  • Once that model fails it is almost impossible to fix it. It has been discontinued by the Maker and even Tiffin does not have them. You can update to what Tiffin is currently using which is a much better Omnidirectional antenna. It auto scans 360 degrees instead of having to manually rotate with the wall remote. Doug
  • Not sure if this helps - but the manual is here: http://manuals.solidsignal.com/HDMS9100_Manual.pdf
    Problem: LCD displays Er
    Possible Causes:
    The position feedback wire (black) is not connected.
    The coaxial cable is not connected.
    The 3 control wires (red, black, blue) are reversed.
    Possible Solutions:
    Connect the wire*
    Connect the cable*
    Correct the wire connection*
    * The receiver should be power reset after fixing the wire connection.
