dianna119
Dec 24, 2016Explorer
Heater Fan wont cycle off
We've been working well for a while but now have a new issue. We replaced the Thermostat a few years ago and all was well. Last winter (1 year ago) I had an issue when the propane heat was on occasionally the fan (set to auto) would try to cycle off when set temp was reached in coach. It actually tries to go off and pops right back on. In summer the basement AC worked fine and the fan cycled off properly. Now here we are in winter again and the fan when set to heat tries to cycle off and jumps back on. I ended up turning it completely off and after turning on/off 3-5 times finally the fan stayed off. I plugged in an electric heater but waking up to 40 degrees inside the rv wasn't fun. Ideas? What is confusing is the fan cycles properly when in AC mode. Can it be the thermostat or something else? Thanks for your input and Merry Christmas.
