Bill.Satellite wrote:
I should have said that a coach wired for 50 amp is required. Can we agree on that? I have not seen a Cheap Heat system that was available for coaches that could only supply 120V power on 1 leg since the 5000W option would never be available. I get it that you either work for Cheap Heat or believe that only you "get it" but for most folks, Cheap Heat is neither cheap or practical.
Not required at all, a smaller coach with only a 30 amp service can be wired for 1,800 watt setting. On the 1,800 watt setting it is run on a 20 amp CB.
It is true that the 5,000 watt setting will not be available on a 30 amp service in the RV.
