Chainwright
Apr 29, 2018Explorer
msturtz wrote:
My issues with the Ford F53 chassis is you are pushing a gasoline engine and drivetrain very hard to get to 26,000# GVWR. The low tow rating further limits the utility of an F53 gas rig for pulling a toad. The rear overhang is very long and unless they have changed it the 45 degree wheel cut means the turning radius is closer to a much longer DP coach (common DP units have a 55 degree wheel cut a front overhang and smaller rear overhang). This isn't to mention the extra heat and noise with the giant V10 under my feet. The ease of service was a myth for me. No regular Ford dealership would work on my gas motorhome. I had to take it only to authorized Ford truck shops in major cities. That severely limited my service options. With my DP most any commercial truck repair shop will work on it. Side benefit is the commercial truck shops repair hours are great. Many shops are open 24x7 others are open till midnight. If you don't need to tow, don't mind heat and noise and a comparatively poor turning radius they can be a good option.
thanks so much. Beautiful and exhaustive answer.
38,708 PostsLatest Activity: Mar 05, 2025
