jannlanz's avatar
jannlanz
Help pls. 2003 Monaco Diplomat Water Pump Fuse Location
Hello, I am on the road with my 2003 Monavo Diplomat and can not locate the water pump fuse box. Water pump is new and worked a month ago just fine. Can someone please tell me where I can find its fuse? I've been on the phone with rv repair people and we still can't locate and it. Traveling with dogs and it would very very helpful to check that fuse. Nothing I have seen anywhere has been labeled "water pump". Thank you so much!!
  • Also, there are 12 volt fuses located in the bedroom upper cabinet. Not one of them says water pump on them. Thank you.
  • I think there is an inline fuse, but I'm so bad at this stuff I would actually need a picture to recognize it. I've been looking at pics and reading and I still can't figure out what they are taking about. The pics I've seen are of the water pump area, but I don't know what they look like. What color is it and what kind of fuse would it take? Thank you so much.
  • Since the water pump was changed, it is possible that there is an inline fuse located right near the water pump itself.
  • Most of my 12v fuses are in a panel in the closet behind a panel. You have a few screws to remove and there they are. I am not sure about yours but I would look there.
