kuziwk
Apr 14, 2016Explorer
Help Wiring New Converter to Motorhome
Hey Guys im a little confused on how to wire up my PD9260 power converter. Can someone help me?
I was looking at installing a basic DC Fuse board, like marine or automotive application and there is no spot for ground...do I need this?
I would get a 12v DC terminal block and have the batteries positive lead connected with an inline 60 amp fuse, than connect the new converters positive lead to the block. Than run a wire from there to the DC fuse block.
From there I was planning on using another terminal block and connect the charge converters negative lead to the negative lead of the battery. However, I noticed that my current old allanson converter charger's negative wire is not going direct to the battery but to a ground location in the engine bay, does this matter? I was planning on using the same spot and just running new 4 awG wire.
Also there is a 10 AWG ground wire going to the frame of the motorhome under, is this fine for the PD9260's chassy ground?
