pariesExplorerAug 04, 2022help with outlets not working in 2019 pacearrow 36uHello, i have a 2019 fleetwood pacearrow 36u the two outlets one the main bedroom slideout have quit working. I have checked each plug and the look ok I have checked the breakers i have check...Show More
USAFBILLExplorerAug 05, 2022Slideouts are noted for causing electrical issues.....check under the slide if you can see any wiring.
Related ContentAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problem2003 newmar freightliner speedometer stopped workingNot all Aftermarket bumpers work
