RCtime
Sep 16, 2013Explorer
RCtime wrote:
http://www.rv.net/Forum/index.cfm/fuseaction/thread/tid/26852543/srt/pa/pging/1/page/1.cfm
Check out this thread. I made a fuse switch for $12.67. It works like a charm installed on my 2013 Honda crv.
Previously I had a 2004 Honda crv that I could tow all day long and multiple days with no battery starting problems, However the newer crv's have more hidden parasitic elect. draws on them that will deplete your battery.
Yes a charge line or install a fuse switch.
In my case I did not have a 12Volts at my elect. pin connector and this was a super easy solution that works just fine and easier than running another wire etc. from coach to crv.
to answer your question, your manual states to remove the radio fuse #34, in the diagram in the owners manual it is a 7.5 amp. fuse, the 1st fuse in the top row of four fuses.
38,769 PostsLatest Activity: Mar 31, 2026
