rgatijnet1
Oct 16, 2016Explorer III
Just remember that for any given weight, it doesn't matter if you have F or G rated tires. It takes the same air pressure to hold the same weight. The only advantage to G rated tires is they will hold more weight, but you have to increase the air pressure to do that. Where your F rated tires may max out at 100 PSI you G rated ties might go to 120 PSI.
38,769 PostsLatest Activity: Apr 24, 2002
