rgatijnet1
Oct 16, 2016Explorer III
usersmanual wrote:rgatijnet1 wrote:
Just remember that for any given weight, it doesn't matter if you have F or G rated tires. It takes the same air pressure to hold the same weight. The only advantage to G rated tires is they will hold more weight, but you have to increase the air pressure to do that. Where your F rated tires may max out at 100 PSI you G rated ties might go to 120 PSI.
I think he knows that.What he asked was how many pounds does he need to carry to support the weight he is currently carrying
he says hes at 90 lbs and I contend hes good to go based on his posted Tire pressures and ratings
It is wonderful that you know what the OP knows about his tire, even tho he doesn't know about a tire chart for RV's. My point was that there was no need for him to upgrade to G rated tires since his F rated tires could easily carry the 14,400 pounds on his rear axle.
38,769 PostsLatest Activity: Apr 24, 2002
