bobkatmsu's avatar
bobkatmsu
HWH leveler problem
I have HWH levelers on my 2010 DSDP, leveler model #AP40289. The following is the problem:This happens in both automatic deployment or manual. I deploy the jacks automatically and it operates as it should. Withing a minute of shutting itself off, the passenger side of the coach starts to "settle" and will drop a number of inches, the jacks on the passenger side remain in contact with the ground. At the same time, the rear driver side jack raises totally off the ground between an inch or two. As it is Saturday and HWH is closed, I thought I would turn to you guys.
  • bobkatmsu wrote:
    MrWizard wrote:
    Retract everything, then check fluid level in the hydraulic resivoir
    If the resivoir is full
    You have leaky valves for those Jack's, the valves are on the manifold at the pump
    If low you have Jack's that are leaking fluid
    If so you should be able to find red ATF fluid on the Piston or fitting that is leaking
    Retracted as you suggested. Reservoir is a little low but not much. I checked for the red fluid and found none. I tried auto leveling again, that was 15 minutes ago and so far, it is holding fine. Could it be Gremlins?
    1. RED ATF may not have been used. Most OEM's use HWH fluid which IS ATF without the red dye. That means the fluid is clear like motor oil, you still look for wetness.
    2. EACH Jack has a solenoid. So, if you have ANY Jacks that settles(raise up) or comes OFF the ground a few inches, that is the solenoid/s leaking internally
    3. What I do when this happens is to open all 4 solenoids manually and run the hydraulic pump for about 30 seconds. That allows any possible trash/debris that may have stuck in the solenoid needle valve to be flushed out. Once you do this close all 4 solenoid valves and retest. IF you have a jack that still settles or retracts and NO visible leaks, then the offending solenoids will have to be replaced. Doug
    2.
  • Retract everything, then check fluid level in the hydraulic resivoir
  • Sounds like a leaky solenoid valve.
    Might operate the bad side manually several times and see if it clears up.
