mrlightrail's avatar
mrlightrail
HWH levelling jacks fluid tank
Got a 91 Pace Arrow 30' on the P30 Chassis, and I need to top off the hydraulic fluid for the HWH jacks. I've looked EVERYWHERE, and cannot find it.
  • It might be a good idea to raise all the jacks and pull in the slides (if they are hydraulic) before you add fluid. Top it off with jacks down and when they retract you will have an overflow
  • Tank is part of the pump. There is a vent cap on top about 1.5 inches in diameter. It unscrews to add/check fluid.
    This diagram may help. This may not be your model but does show configuration
    Pump
  • enblethen wrote:
    Right front. In front of tire in fender well.
    I can see mine with hood open looking down on driver's side.
    I see the pump there. the lines lead to the main control box, then off to the jacks. Still don't see a tank.
  • Right front. In front of tire in fender well.
  • on my 96 the tank is located between the frame rails about midway of coach
  • My cousin had a PA but it was older and the tank was behind the rt front tire on the frame. A big pain to fill. If not there just follow the lines
