If not using for an ice maker, a freezer makes sense to freeze the items you want frozen before you put them in your dometic or Notcold.
As you know, putting fresh lbs to freeze with your already frozen items raises the temperature considerably in the freezer compartment.This continual operation will cause food to spoil faster than you may think.
The Uline or Dometic costs approx 1500.00 dollars if it is anything like the two I have used.
Ice made at that speed is great if you plan on a knee operation or anything related that requires cold compression.
You may not be part of the party but someone always appreciates an abundance of ice in the campground. make new friends...break the ice
Great for the geo people that recommend ice cubes in the black tank to bang around down there and clean it out while driving.
Better yet to fill a cooler on a hot day or for a toad trip.
Assist your "on the way out" norcold refrigerator with buckets of ice in the frig to save your food.
Nothing quite like serving crab and prawns "on ice" under the awning in sizzling heat.
