cableguy574ExplorerMay 18, 2013Inside step coverMy inside step cover stop working, the motor runs but the step just slides in & out by hand.. Any ideas, it looks like a nut or a pin is missing
fcooperExplorer IIMay 19, 2013See if you can see any of the push/pull assembly from under the step cover when the cover is extended by hand. My air operated one had wood screws that pulled out of the leading edge of the step cover.Fred
Related ContentReplace insulation inside heater column.2007 Thor Mandalay 40H power step stop workingStep cover stopped workingStepsInside Step Pads
