kwplot34's avatar
kwplot34
installing digital t-stat help needed
I purchased a Honeywell digital t-stat RTH2410B. I have looked at a video posted here on installing a new controller. The problem is, in the video he only has 5 wires, red, yellow, white, green, gray. I have those wires plus a light blue wire. And according to the owners manual and installation instructions in the motor home, that wire is a 12V- wire. where do I hook it up at? The back of the new controller has B,O,G,Y,W/AUX,NOT USED,R AND Rc. R and Rc has a jumper across them from factory. I have red hooked to R ,yellow to Y, w to white, grey and green are the fan speed.
  • kwplot34 wrote:
    I am using the option for the 5 min delay on compressor start up, seems like a safe move. you can turn that feature off. I did not install a switch so I can have low or high fan speeds, wired it so its on high all the time with the green wire. The grey wire for low is taped up so if I decide to install the switch later its right behind the t-stat.
    I have been using a Honeywell smart thermostat for several years now. I wired mine up only using the high AC fan speed like you did, and have never felt a need to hook up the switch for the low speed. But I wasn't sure at the time, so the option is there.
  • Sam Spade wrote:
    kwplot34 wrote:
    Plugged the shore power in, and now everything works perfect. LOL.
    Maybe not.
    Having the AC power on will give you the 24V from the furnace/AC controller board probably.
    If your heat is supposed to work when on battery power only, that might NOT work still.
    (Oops. I see this has been answered already.)
    Yea, with the shore power disconnected, the gen set off, just the coach batteries connected the heater still works.
  • kwplot34 wrote:
    Sam Spade wrote:
    Maybe not.
    And there is NO 24V DC ......it is 12V DC from battery or converter which is used by the residential t-stat.
