sjverkayk's avatar
sjverkayk
Itasca Sunstar 30T or Winnebago Vista 30T Owners
If you are or have been an owner of one of the above models, we would be interested in hearing about your experiences regarding the handling, instrument panel viewing and communications with the dealer, Winnebago and Ford. If you have made any modifications to make the vehicle safer, please let us know what those were, the costs and how satisfied you have been with those modifications. This is our first RV and we purchased this vehicle because we trusted the Winnebago name and, at the time, did not find any negative reviews for this model.
We have found the vehicle to not track when driving at highway speeds and almost lost control when encountering winds of about 15mph. The other issue is that you can not read the instrument panel when driving in sunny conditions due to the glare from the sun on the plexiglass. We have been in contact with Winnebago, Ford and the dealer. We have since learned that there is a weight distribution issue between the front and rear as well as side to side. This causes the front end to float at higher speeds and to pull to the drivers side. Ford says that there should be at least 35% of the weight over the front axle. Per our scale tickets, this is not the case but Winnebago states that they are in compliance with Ford specs for this chassis.
The local Ford dealer did suggest we take it to a company that specializes in RV suspensions. They say they can correct the handling issues, but when we contacted the manufacturer, Winnebago customer service rep stated that if we were to make the aftermarket suspension modifications, our warranty would be voided. We then contacted the dealer and delivered it to their service department in hopes that the vehicle could be repaired under the warranty.
So, after purchasing in August 2013 and taking two trips, the vehicle has not been used since we delivered it to the dealer on October 14, 2013. If you prefer to not post a reply on the forum, you can email us directly at winnebagowoes@gmail.com.
Thanks for listening.
  • Thank you again for the post. I did leave some detail out in my original posting. We did have an alignment done and the tires balanced. Per Goodyear, the tires are at 85psi. Would 80psi make that much of a difference? We also installed a stabilizer bar in the front. These changes did not make much of a difference in our case. So, we are looking at the more extensive modifications. Do you travel with a tow vehicle and water in the fresh water tank? Any issues with that?
    While we are new to RVs, we have owned several travel trailers and a 5th wheel. My husband was a truck driver for over 25 years and was also a certified truck driving instructor. After leaving the trucking industry, he drove for Greyhound for a couple of years and was a city bus driver for about 5 years. So, he can pretty much handle anything and is amazed that if this were a commercial vehicle it would not be allowed on the highway. Since I am inexperienced, he is concerned for my safety and I have not driven it except for on city streets.
    We have taken the vehicle to a Ford dealer after having it scaled per Ford Chassis Division. It was the service advisor that noted on the service ticket the scale results, which showed that there was less than 35% of the weight over the front axle, he also noted that the front bins were fully loaded and the rear bins lightly loaded, that there was no water in the fresh water tank and that there was a full tank of gas. He also noted the equipment distribution between the driver and passenger sides, which may cause the vehicle to pull to the right. He then noted that there was over 50% of the vehicle behind the rear axle (132" behind axle on a 190" wheelbase).
    Add this all together and it shows a vehicle that should be on a longer wheelbase and will have poor handling characteristics. I am hoping that by posting this information, it will help others in making a more informed decision. I was just so excited about the vehicle layout and features, that we didn't spend much time educating ourselves.
    I am happy to hear that this is correctable.
  • sjverkayk wrote:
    We are concerned that our warranty would be voided if we were to make such changes. Had you heard anything similar regarding your modifications?
    We are new to RVs, so we were alarmed that we would have to make modifications to correct the handling issues due to what appears to be a design defect in how they placed equipment under the coach. Is it typical in the RV industry for the customer to eat those costs and forfeit their warranty?
    Warranty would only be in question if the modification caused failure of another part that was under warranty. The parts you are replacing/adding are extremely unlikely to negatively impact other components.
    BUYERS are at fault for less than exemplary chassis. I know that should harsh, but if coach manufacturer A spend an extra $600 on suspension and another coach manufacturer B spent an extra $600 on upgrading interior fabric, which do you think would sell more coaches??
    Until buyers are willing to pay more for a good riding and handling chassis AND they convey that information to the coach makers, assume that you, the buyer will need to do these upgrades after purchase. And, today's gas coaches are on much better chassis than were available in the past.
    Please do not assume that I agree with this, but it IS the way it is.
    BTW, I present the Suspension Seminars at FMCA Conventions, so am reasonably familiar with how this works.
  • I had no idea about warranty being voided although I have had no warranty work on either 30W or the current 30T on anything involved with suspension. From what I have read modifications are common. You are new to the motorhome so it will take awhile to get used to driving it. Remember it is a kite. I would first do the cheap handling fix and also adjust tire inflation. I would also then add a good steering stabilizer. See how that goes and work from there. Cheapest things first and build. I do think a good rear trac bar will be important as well. Keep us posted on how it works and what you learn.
  • Thank you for your response. The detail you provided is very helpful and it is in line with the modifications that are being recommended to us. Sounds like those changes were successful. We are concerned that our warranty would be voided if we were to make such changes. Had you heard anything similar regarding your modifications?
  • One more thing. Henderson Line up in Grand Pass Oregon are great experts on suspension. Call them and perhaps even pay a visit.
  • Check out the older thread on the 30W and you will get a lot of info. I have a 30T and had a 30W. Yes it rides rough so I have modified at my own expense to overcome the fact it is light and on 19.5 inch wheels v. 22 inch of the next higher coaches like Sightseer. Have not had an issue with seeing dash. So here is the order of things to do that many of us have done to make it a nice coach. First you need a steering stabilizer. The best is the Roadmaster from general opinion but Steer Safe or Safe T Steer may be ok. Then a rear trac bar. Tiger trac from Blue Ox is good. I also changed shocks to Koni FSD and then added the Kelderman air ride and that is about 6 grand so you may not want to go that far. I was willing to pay for a great ride. Tire inflation is important. Don't over inflate. Most of us find around 80 works with the weight and can even do less on front. Finally the "Cheap handling fix", search for thread is great. It just requires moving the sway bar to tighter holes front an back. Let me know if you desire more info. Unfortunately it will cost some money to get the coach to where you want it. Sounds like your tires are way over inflated to get the float feeling. I now drive in 35 mph cross winds easily. The steering stabilizer is also a safety thing in case of blowouts you will track.
