etruittExplorerJul 08, 2014jack pads for motorhomeNo camper dealers in my area so looked on the internet for jack pads. There is a lot of them out there each one a little thicker or thinner, and a little difference in shape. What do you use?
Tom_NExplorerJul 08, 2014I carry four 12x12x3/4" pressure treated plywood boards.I drilled a 1/4" hole in opposite corners of the boards. I can then slide then under the jacks and remove them with my AWNING PULL ROD. -Tom
Related Contentjack padsSnap Pad Jack PadsNeed ideas for stabilizer jack pads.Leveling Blocks vs jack padsLeveling Jack Pads
