Sarahdove's avatar
Sarahdove
Laminate flooring install
Hello Happy Campers,
Has anyone pulled up the flooring including the carpet and replaced it with the laminate planks? We just purchased a used class A and would like to replace the flooring.
Thanks for any input.
Sarah and Nick
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yup.. Now I did a slide. it's not that great with a slide as the "lap" ..well. that's kind of different. had to re-carpet that.
    laid a carpet runner (cut lengthwise) down with furring strip on one side so it covered the joint.. Worked well. Looked good. (Cut edge under the strip by the way)
  • I took on the task and the install was a day project. What took longer was that after I had pulled up the old flooring, I put on two coats of polyurethane to protect the floor from moisture and to lock out any odors that were in the sub floor. I used matching quarter round on the edges.
