willald wrote:
dougrainer wrote:
Your problem is a BAD motor. Regardless  of you replacing it a few years ago. This is a very common problem with LCI(Coach) steps. BTW Have you had the recall done to the steps? Double and Triple LCI steps have a very important Safety recall to install a brace under the pivot bolt for the Pie Gear. The other possible problem is if you have sheared off Gear teeth on that Pie shaped Gear assbly. This is easily seen when underneath the steps. Doug
https://lci-support-doc.s3.amazonaws.com/recall/ccd_0002553.pdf
Ahh, Doug, was hoping you'd respond.  Have read, seen many of your posts, know that you are very knowledgeable on these things since you work on them.
No, have not had the recall done.  Thanks for the info, I will look into getting that done.
Man, I **HOPE** it isn't the motor!  I replaced it once, and remember it being a royal PITA getting all those screws, spacers, etc. lined up just right to put the new motor in.  Soooo don't want to do that again!
Have you seen where specifically this happens (motor won't shut off), and it turned out to be the motor?
I was thinking gear teeth also, and looked at them closely.  Gear teeth on both the pie gear and the motor look OK.
If the Pie gear teeth are OK, your motor is bad. Now, LCI will upgrade you to a Kwikee for a cost, if you choose not to have the recall done.  Doug
GET THE RECALL DONE ASAP. YOU CAN GET SERIOUSLY HURT IF THE STEP FAILS.
