dougrainer wrote:
If the Pie gear teeth are OK, your motor is bad. Now, LCI will upgrade you to a Kwikee for a cost, if you choose not to have the recall done.  Doug
GET THE RECALL DONE ASAP. YOU CAN GET SERIOUSLY HURT IF THE STEP FAILS.
Thanks, Doug.  Indeed, you are right, it is the motor.  :(
After looking closer at the cam stops I noted initially in this thread, I can see that they are not the problem at all.  That leaves just the motor itself, or more likely the gearing inside it has worn out.  I just ordered the new motor from Amazon, it'll be here early next week.  Not looking forward to wrestling all those spacers around the motor back in place when replacing it, but is what it is.
This will be the 2nd time I've had to replace this motor.  Last time was about 4 or 5 years ago.  This seems to be a common failure point.
Doug, do you know if the Kwikee upgrade you mentioned, has a motor that is any more reliable?  If so, I could be tempted to just replace the whole step unit.  Don't want to keep replacing a $162 motor every few years.
