zman-az wrote:
(snip)...As mentioned most diesels do let air out then level. Of course there is always someone that will have an exception. What I don't know is if the dp levelers have more travel than gassers. There have been times on my gasser that I have had the front tires off the ground to get level. Have not done that yet with our dp.
Actually, I am able to lift the front of my DP off the ground quite a bit. In fact, the one time that I had to have it towed, I was able to lift the front high enough to then set it down into the tow cradle when the tow driver placed it underneath the wheels.
