Lobstah wrote:
Mr.Mark wrote:
The small problem was that the sites are slanted with the front of the site being the higher end. I put down the hydraulic jacks and during the night, we started sliding backwards even though none of the tires were off of the ground. Early in the morning, I started the engine to air up the bags and leveled on the air bags (no more sliding).
MM.
I'm not sure I understand what you're saying here.
You leveled the rig, your wheels were still on the ground, yet you "slid" backwards?
Only way I could see this happening is if your brake wasn't set and your transmission was in neutral?
Never heard of a rig sliding downhill. Were there skid marks from dragging the tires?
Jim
Jim,
We were moving 'ever-so-slightly' backwards. Every so often we felt a vibration, probably moving just a fraction of an inch. The hydraulic jacks lifted the rear wheels just enough where the tires were touching but not firmly planted. It did run across my mind that this motion could have bent the hydraulic jacks but they look good and sturdy.
Our jacks will not deploy unless I have the air control pulled that engages the parking brake.
This has jogged another memory at the same park in the older section. We were parked on a very level spot watching TV and the coach started jiggling. It took a few minutes to realize what was happening.... we were sinking. A closer inspection revealed that we were crushing the already broken concrete pad with the rear jacks. I started up the engine and leveled on the airbags.
MM.
