My coach doesnt have leveling jacks and i was wondering what you use to tell you when the coach is level. ( stick level on the floor of the rv, etc...) also if you use the stick on bubble levels, whe...
I have used Hoppy Levels for many years. Mount them where you can see them from the drivers seat and choose the most level spot you can find. Then place leveling blocks as indicated by the levels.
Install them initially by leveling the refrig with a carpenter's level, then mount the Hoppy levels
