First of all I found that if you place a bulls eye level on the counsel between the front seats WHEN you pull in, that will assist you in finding the most level spot that is on the site before you even get out of the RV!
After using this method I found that most times it totally eliminated having to use levelers under the tires!!
I started out using the Lynx honey come levelers. But they crack. Especially in sand they just crack right up when you pull up on them.
After buying my third set of those I switched to the solid ones. Still using the same ones.
And btw you will need to buy 2 sets.
