suprz
Apr 24, 2015Explorer
Leveling class C
My coach doesnt have leveling jacks and i was wondering what you use to tell you when the coach is level. ( stick level on the floor of the rv, etc...) also if you use the stick on bubble levels, whe...
rockhillmanor wrote:
First of all I found that if you place a bulls eye level on the counsel between the front seats WHEN you pull in, that will assist you in finding the most level spot that is on the site before you even get out of the RV!
After using this method I found that most times it totally eliminated having to use levelers under the tires!!
I started out using the Lynx honey come levelers. But they crack. Especially in sand they just crack right up when you pull up on them.
After buying my third set of those I switched to the solid ones. Still using the same
ones.
I don't have one set of the yellow blocks, I will get a second set. I like the bullseye levels. I was thinking about getting one and at least setting it on the floor in front of the fridge to get an initial reading when first pulling into a spot. Then moving it to another spot etc... I like not having to get out of the drivers seat to get a reading also. So..I'm thinking one on the doghouse is a good idea too. With a 31 ft coach, I know that the off level will multiply the further from the true level I go
And btw you will need to buy 2 sets.
