willald
Nov 01, 2021Explorer II
I am not a fan of snap pads, or any pad you permanently mount on the end of your jacks. They can be very expensive, and they accomplish very little in terms of added stability. They reduce your ground clearance when on the road, too. On top of that, they do nothing to help you to level things out when on a very unlevel site.
I much prefer my 'dirty wood blocks' and the way you can stack them at each corner to minimize how far your jacks have to extend, and drive one side up on them when site is very unlevel. Extending the jacks less is also easier on the jacks, and makes things much more stable inside.
Much cheaper this way, too. If one cracks, all I have to do is go to a local lumber store and buy another piece of 2x10 or 2x12 and cut it (or have them cut it) into squares.
As to slideout supports: I've never used them, nor ever owned an RV that recommended using them. Would probably be a good idea if you were going to be parked for extended periods, but not sure if they are worth the trouble, otherwise.
38,783 PostsLatest Activity: Sep 23, 2026
