I have recently purchased the
Quadra Manufacturing Big Foot EZ System for our 2005 Winnebago Aspect 23D. As with any change to your motorhome as it came from the manufacturer, do your research to determine if the intended modification is appropriate. I came to the conclusion that the Big Foot system would best fit
our application.
Yes, welding on any chassis component is something that needs to be approached with the correct knowledge and tool but, most competent fabricators can do this installation correctly and without any difficulty. If you are concerned about welding on your particular coach, find out from a professional. Here is information directly from Ford about the correct procedure for
welding on the Ford chassis that I referred to prior to making my decision on the Big Foot system. Yes, you can safely and correctly weld on a vehicle.
If you are unable to do this installation yourself, determine where you must have the work completed before you decide what system to use. The Big Foot system I have selected can very easily be installed by the owner if they have appropriate knowledge and access to the necessary tools. It is not a difficult procedure for the experienced "do-it-yourselfer".
