GTMADNS
Jun 22, 2014Explorer
Leveling springs
Broke one of the leveling springs yesterday on my dp. I found part number already and a lot of places to buy them. How hard is it to change them? Is it easy to do and is there any tricks to do it?
oldchief7155 wrote:
Won'the work on a DP. Springs too short and way to strong.
dakdave wrote:
the way bumpy descibed is much easier than goofing around with shims or washers
Dale.Traveling wrote:that is a really good idea.
The hard part is you will need to expand the spring to install. Even when the jack is fully retracted the spring are still pulling the jack up. Probably the best way is to get a couple of dozen of wood shims then bend the spring to open the turns so you can wedge the shims in one at a time until enough are in to expand the spring enough to reach both hooks on the jack. Alternate the shims on each side of the spring so it expands straight. I've seen postings where others have attached the spring between two vehicles to expand enough to get the shims in. What ever will work best for you. Once installed extend the jack and the shims will fall out.
