Hi, need help. The overhead light (NOT the halogen press in ones) with the two small bulbs broke and we had it "fixed" under warranty. It is not working again. We want to replace the light fixture. Do...
If you are looking at putting a new fixture in the same spot you may have a problem. If your current light has a bad connection someplace changing the fixture won't help. A normal spot would be finding the ground connection. Try looking for "RV lighting Fixtures".
