AL49er's avatar
AL49er
Looking for a fuse
I have a 2004 Kountry Star D/P and it has a small solar panel on top
that does not work any more. Can you tell me is there a fuse some where? I have looked in the book that came with the rv but can not find it. Thanks so much.
  • I found the fuse on a small wire maybe #12 going to the battery Positive side. I think there was another one inside under the dash connected to a light that showed on the dash. Too many years ago. Maybe Doug will ring in . I run new wire on mine and installed a bigger panel and only used one fuse near the battery.
    Can you use a voltmeter to determine if voltage is present at the solar panel and before going any further?
