jerrysharonSLAExplorerJun 07, 2014loss of power "check engine light on2004 Workhorse 8100 engine. 37 ft Winnebago Class A. This happened at high RPM while climbing a steep grade. Motorhome is in the shop now and they can't find a problem. This has happened before on lev...Show More
enblethenNomadJun 07, 2014Sounds like a problem the throttle position sensor. It could have a loose connector.OBD II codes
Related ContentDash "Check engine"Potential engine overheatingNo power on outside GFCI outletNear engine overheating gaugeAdding power outlets in slide with no wiring
