rowekmr
May 29, 2017Explorer
Low voltage on 2000 Dutch Star 8.3L
Helllo
Just picked up a 2000 Newmar Dutch Star that has been sitting for 4-5 years (long story). Both chassis batteries replaced recently and had a pre trip inspection by a mobile mechanic before I picked it up. Starting in FL voltmeter was above 12v and by Atlanta it was bouncing from 8-11v. I had generator on for roof air. Stopped by Love service center and counter guy used a voltmeter and confirmed 11v with engine running and no electrical load. Couldn't repair it there so stopped at Walmart and shut engine off but left generator on. Tried to restart to see how low and it didn't start engine and shut generator off. Used the switch to couple house batteries and started generator and went in and got a 40amp battery charger and 50' thick gauge extension cord. I plugged in charger in garage outlet and set charger on 40 amps. I checked the specs of Interstate chassis batteries (31 MHD) and they are rated at 1190 amps.
Does it sound like alternator failure?
I plan on charging for 7 hours will that last the 10 hour ride home if I turn off all electrical loads?
Any other suggestions?
