wallynm wrote:
This is a classic Monaco problem and in some cases they simply remove the noise maker from under the dash.
It is NOT a classic Monaco problem. Where do you get your info on this???? Doug- wallynmExplorerThis is a classic Monaco problem and in some cases they simply remove the noise maker from under the dash.
- rgatijnet1Explorer III
Skyfarmer wrote:
I've not filled it when the jacks are down. Manual says to extend one jack and then fill. Will try that in the morning. Dennis, how do you know when it's the "correct" level? I've filled it until it runs over the side. Very frustrating.
Manual says to extend ONE jack 4-6" and then fill until alarm goes off. It is important that the coach be sitting on a level surface at the time since it will affect the fluid level in the system. - Monaco used 3 different brands of Jacks. NOBODY can give you any help until you state what brand jacks as each brand has its own style down alarm system. Doug
- 2ndhomExplorer
Skyfarmer wrote:
After jacks are retracted it will still ring. Sometimes it will go off after a short time, sometimes stays on.
Maybe that's the bell ring to tell you "low air pressure"? - SkyfarmerExplorerI've not filled it when the jacks are down. Manual says to extend one jack and then fill. Will try that in the morning. Dennis, how do you know when it's the "correct" level? I've filled it until it runs over the side. Very frustrating.
- What brand jacks? Doug
- Executive45Explorer IIIThe alarm is very sensitive. Did you fill the reservoir while the jacks were extended? If so, the res is probably too full. Too full will give you the same result as too low... I used to fill mine to the correct level, then I made my own "dipstick" using a tent stake. Put it in the reservoir top and mark the "full" spot. Makes refilling easy and accurate...disconnecting it could lead to an expensive fix if one of the jacks doesn't retract and you are aware of it...just sayin...Dennis
- Thunder_MountaiExplorer IIMine does and always has done that on our 2007HR Endeavor. Always turns off after a bit. Also, check fluid level. Ours is VERY sensitive. Just the slightest bit low and it get the alarm. May or may not be your issue.
- SkyfarmerExplorerAfter jacks are retracted it will still ring. Sometimes it will go off after a short time, sometimes stays on.
