rgatijnet1 wrote:
Wooden cabinet sides, and loose dash panels, can all cause squeaks and rattles. It's not right, but sometimes these things can be difficult to find. Dash squeaks can sometimes be found with a little baby powder sprinkled around to lubricate the rubbing. If it stops, you have found the area that needs further attention.
Poor weather strip sealing around the door could be causing the wind noise. You may try putting a little petroleum jelly on the door gasket and see if this helps. It will also show you if the weather gasket is making full contact with the other side. Keep in mind that if the door is a little loose on it's hinges, the air passing by, as you drive, may actually pull the door away from the coach causing air noise.
X-2 I agree with your post Ronnie! And sometimes people forget your driving a large truck with a house built on it! You won't get the same ride as a car or pickup truck. If the road surface is not perfectly straight your going to have flex which makes lots of different noises. The power steering shouldn't be making the noise your describing it needs to be looked at! I play the music a little louder in my coach when driving so the little noises here and there don't drive me nuts!
