OCDbikr's avatar
OCDbikr
Explorer II
Feb 12, 2016
Motorcycle on a hitch?
So, I'm a newby here guys. My name's Rob and I haven't bought my RV yet, but it's just a very short time away, as I am getting a sizeable settlement soon. That being said, I am certainly buying one and it will MOST likely be a class C but I may explore other options. I live in a large metropolitan area and will be living in the RV full time, shortly after the acquisition. It would obviously be wise to have a secondary means of transportation to save on fuel costs and relieve myself of the difficulty of navigating a very large vehicle, through city streets on a daily basis. I plan on buying a motorcycle as my second vehicle and wish to carry it with me wherever I go... (NOTE: I won't be traveling much. I primarily plan on staying pretty close to my hometown, as it is my comfort zone and I like it here, though I may make the occasional trip several times a year for the adventure of it.) I have watched a few videos of people carrying full sized bikes on their hitches with minimal modification but have one thing that keeps popping up in my mind every time I entertain the idea or explore the concept: Do I need to or would it behoove me to strengthen my rear suspension system with a more progressive or "longer-travel" shock??? My bike will be 550lbs. That is the equivalent of two 225lb. guys in the back of the RV... Should my factory shocks be able to handle driving on a regular basis with that amount of weight welded to the tongue of my hitch? I dunno! Are there any people here that have experience (preferably not opinions) with this type of scenario? I would love to hear what you have gone through and how your actions have either helped or hurt you. Looking forward to good reading in this thread. Thanks guys and gals!
  • Thanks for the replies so soon guys. A few things to note as addressed above to merit mentioning: I am a welder/fabricator by trade and there is no hauler on the market that I wouldn't do my own additional strengthening to. That being said, I would also weld up a more supportive receiving system for the hitch itself to increase its tongue weight capacity. I'm certainly not going into this in the dark and have a good understanding of steel and welding. I also have within one mile of my house, a free dump station for black/gray water tanks and that is a real convenience that I will surely take advantage of and part (even if a small) reason that I desire to remain in this immediate area. Another part of my reasoning is my personal experience with the RV habits in this immediate area... It certainly is against the law to park on any city street overnight here. HOWEVER, in my own neighborhood even there are dozens of RVers that frequent the curbs at night and nothing ever happens to them. There is an overwhelming population of permanent RVers in this area and it makes it extremely difficult to dedicate man hours to enforcing these regulations, when there are more urgent crimes that need attending to. So- I figure that I'm of more than average intelligence and if they can do it full time, SURELY I can do it here in my own hometown, where I personally know the area inside and out... Back to the hitch though... I have considered towing it behind on a trailer or dolly, but I want it to be lifted, to decrease the vulnerability for theft whilst sleeping. I don't wanna be an easy target and on the ground, a Harley can disappear easily if not in a garage or close to someone's front door. Assuming that I have a viable tongue weight capacity because of increased welded support, which type of carrier is best bang for the buck and reliable in its reputation and serviceability? Oh, and I have decided that because of this topic, I WILL go with a Class A, for rating and ease of installing reasons...
  • It's not the shock that does the carrying of the weight but the spring, the shock dampens the bounce of the spring. What you will need to know is the carrying capacity of the rear suspension.
  • You're right to be concerned about the weight and balance issues. Whether or not it's practical will depend on the individual motorhome you're looking at. I think the majority of class C hitches are not rated to have more than 500 pounds tongue weight (and a good many have a lower tongue weight rating than that). You'll probably be pushing 750 pounds by the time you get a carrier and associated odds and ends to get the motorcycle up and down.
    There are a few things specifically to look at. The first, as mentioned above, is the tongue weight limit of the hitch. Do keep in mind that the farther out from the back of the motorhome the motorcycle is, the greater the lever action on the hitch will be, so it would be wise to look for some cushion here. It would be wise, in my opinion, to have a qualified shop check out your ideas and probably fabricate a mount that mounts to the frame directly rather than just the receiver hitch.
    The second is the gross vehicle weight rating and associated carrying capacity (basically the gross weight rating minus the weight of the motorhome with nothing in it). As a general rule, for full-timing in a class C, you'll want to look for the largest carrying capacity you can find; 1500 or 2000 pound is not atypical, and by the time you get water, your motorcycle, and yourself, you'll have used up a significant portion of that.
    The third thing to check is the axle weight limits and the actual axle weights. Adding a lot of weight to the back of the motorhome will cause the front axle to be unloaded some and the rear axle to be loaded more due to the vehicle as a whole acting as a lever. You could be adding maybe 1000 pounds to the rear axle and removing 300 or so from the front axle, as a very very rough example/estimate. Of course this also depends on the wheelbase and overhang of the particular motorhome.
    There are a few other alternatives to porting a motorcycle around that might work better. You may be able to create some sort of a front mount, which often works out somewhat better from a weight distribution point of view (but has its own challenges with engine ventilation and headlights and protecting the motorcycle and so forth). There are also some single-wheel dolly mounts available for the hitch where the front wheel of the motorcycle gets strapped in while the rear wheel rolls along on the road. Finally, you could always get a little trailer of some sort to carry the motorcycle, and whatever else you wished to carry.
    I know you didn't ask about it, but please make sure you have reasonable plans for where you'll generally be staying/parking and how you'll handle water, sewage, electricity, and so forth. A long-term site at a campground is, of course, a viable way to do this and shouldn't cause much if any hassle. On the other hand, simply parking on the street or similar situations is not taken kindly to at all by many California cities.
  • look at a web site mightyhauler.com but I don't think it will work on a class C
    I have done this with 5th wheel and class A but no experience with Cs good luck.
