pulsar wrote:
dougrainer wrote:
I figured you had the MCD. But, when you stated it would retract when the motor failed, that got me thinking. Yes, there is a spring in the MCD Gold Series. But, IF the motor fails the shade will do nothing. It will NOT retract and it will NOT fall down because of an extra spring. You then have to use a clothes pin or something to pin it up if it fails where it blocks your vision. But, as I stated, it will NOT auto retract when the motor fails. Doug
So, you are saying that this statement, "The Solar/Night Shade in your vehicle is equipped with an Automatic Safety Retraction feature, which will retract the Solar/Night Shade to the full upper position in the rare event of an internal motor failure." from the Winnebago Owner's manual and this one, "MCD Switch controlled motors for windshield applications are designed to automatically retract the day or night shade into the full up position in the unlikely event a motor fails." from the product manual and the MCD website are false?
Do you have a source?
Thanks,
Tom
My "source" is MCD. I called them as I have never heard of that operation and wanted to know if they built a special model. NO, they stated and they explained just what I posted. I deal with both MCD and Auto-Motion which are the 2 major makers of RV electric shades. Doug
Just talked to MCD again. They stated that in theory the shade may FULLY retract, but the design is to make sure that small internal spring keeps the shade from falling down and usually just raises a few inches instead of full retraction.
