Executive45
Nov 13, 2014Explorer III
INSIDE the black box are two fuses...one for 12V and one for 120V. If the A/C one is blown make sure you use the correct replacement. Some are sloblo and some are quick blo. I believe the Norcold uses the SloBlo which allows the original jolt from the compressor without blowing.
If you haven't done so, make sure you have power TO the OUTLET. If you have the LRIM, the ice maker should be plugged into the regular outlet and the fridge into the one that runs off the inverter....Dennis
