RayChez
Nov 13, 2014Explorer
What is it doing when on propane? Sometimes when the flu is dirty it will not run on propane. Need to clean it out. They clean mine out with what looked like a oxygen bottle, but it might have been something else besides oxygen. They blew into the flu, then it worked.
On mine also in the box where the board is located there are two five amp fuses. Check to see if both are OK.
Dry camping? I guess you were running the generator to get AC power or the invertor. Ac power would also have a circuit breaker not a fuse. So check your circuit breakers. On mine they are by the bed box. Not sure where yours are.
