Gridley's avatar
Gridley
Need help switching to AGM coach batteries
Hello,
We have a 2007, class A, diesel pusher on a Freightliner Chassis. A National Tropical 37 ft. The original coach batteries are due for replacemnt. I would like to switch to AGM batteries. The charger/inverter has a setting for AGM batteries so that should not be a problem.
The issue I am having is trying to find the proper size AGM batteries with the same terminal style as my current Trojan T-105 flooded cell batteries.
Any suggestions for the AGM replacement?
The coach has four 6 volt batteries, configured as two parallel sets of two 6 volt batteries in series. Is there a problem of simply putting four 12 volt batteries in parallel?
Any help would be appreciated.
Gridley
