DAS26miles wrote:
So on the long grade into Death Valley I believe the speed limit is 50 or 55 mph. I have a choice of dropping it into 3rd or using the tow/haul. Going up the long grade from Panamint is it better to drop it into 3rd or use the tow/haul? It doesn't seem clear to me. Is 3rd the same as the 4R100 Drive with O/D off?
Actually, here are the transmission gear ratios from another forum
4r100 gear ratios:
1st - 2.71
2nd - 1.54
3rd - 1.0
4th - .71
5r110 gear ratios:
1st - 3.11
2nd - 2.2
3rd - 1.54
4th - 1.0
5th - .71
So dropping my 5R110 down to 3rd actually would be the equivalent of dropping my old 4R100 down to 2nd. How could I drop it to 4th, nothing on shifter?
In general what I like to see on long upgrades-especially in hot weather- is to have the torque converter locked and the engine RPM in the middle to upper middle ranges of the engine's capability. In the case of the V10 under hard grade I prefer to keep it 3200-3800 RPM. Of course it will not hurt it a bit to to go higher if necessary to get more speed, or passing performance.
As for converter locked, with practice you can feel it by feeding in more throttle and the RPM tracks speed not engine output. Or Scangauge instruments may show it. If converter is locked it isn't generating nearly as much heat. The tow-haul feature has no other voodoo to reduce trans temp other than this-but it may help you achieve this. Several ways to skin a cat here.
In general torque converters generate most heat when active (unlocked) low speed at high load. Poor airflow thru coolers contributes such as backing up or heavy tailwind on steep grade.
FWIW there should be two indicator lights on the dash of all cars/trucks lit when-
1. Torque converter is unlocked.
2. Engine is in open loop (fuel air mix related)
