Golden_HVAC wrote:
To bad they are not putting the Ecoboost in the T-350 for now. I think that most motorhome makers will be waiting on the more powerful V6.
If you look up the Ford Towing Guide, and look on page 21, you can find the Transit GCVWR - it is limited to only 12,000 with the 3.7L gas V6 or 13,500 with the inline 5 Diesel. They do not list the Ecoboost with a Transit cab and chassis. Why I have no idea why they will not put the best engine in the cab and chassis.
Fred.
Ford so far has not used EcoBoost technology in any application where the engine ratings are expected to serve 100% duty cycle. Instead, medium duty trucks use different engine series, and where they overlap with 3/4 ton and 1-ton applications, the shared engines are down-rated from the pickup truck numbers, e.g. when the B-series Cummins is put in Class 6 and Class 7 cab-chassis.
Medium duty trucks use engines differently, sometimes running at full output all day, rather than only for acceleration and short grade climbs. Even in lighter duty applications, some turbocharged engines are computer managed to provide full output for short durations, then cutting back to sustainable outputs for engine preservation.
