MrWizard
Feb 11, 2018Moderator
you would need to retract that 'one'
and then try another one
better to just check the jacks hyd system, pump reservoir
could be stuck valves not opening ? loose corroded connections etc..
with engine off and key on you should hear the pump
just something to think about
IF you go back for a second look
