jeffinpgh's avatar
jeffinpgh
No power to the column
I'm stumped... my 1986 c/g30 Chevy Fleetwood Arrow was running fine and all of a sudden (after I shut it off & wanted to start it 10 minutes later) I had no power. No power to the column. I turn the key in either direction & get nothing... no radio, no blower, no gauge movement, & no start. I replaced the ignition switch last night & still nothing. What would cause this... everything else works, headlights, brake lights, interior courtesy light...
Is there any relays/solenoids that powers up (keeps everything hot) everything BEFORE the key? What fuses should I be replacing if that may be the case & where are they? Would the coil (on top of the cap) do this if it fried itself? Alternator fried? Resistors? I just cant figure out why I'm not getting power.
Second question... can anyone explain in good detail, how would i go about creating a proper hot switch & start button combo to at least get this thing started so I can get it to a shop to be looked at further.
support much appreciated
  • The switch is at the base of the steering column. The linkage travels down the column to it. There is no reason to remove steering.
    Or at least that is the way mine is!
  • Any chance this could be a "shifter position" issue? You know, not in "park"?
  • Found it.. :B
    Inside a heat shield mounted to the transmission.
    Counted the wires going into the shield & there colors (all thick red) & the wires coming out, all were a thinner white. One of them at a fusible link inside the shield was melted & more or less crumbled. SO.. I got the heaviest gauge wire I had, a butt connector, & a 30 amp fuse I had laying in the junk drawer and made a jumper. Told my son to turn the key on & the radio up full blast & as I laid on my back in the mud under the beast. I touched the wires & all of a sudden heard Joyce Meyrs screaming Hallelujah on the radio over & over again.:C OK, back to the subject. I ending up making a new route, away from the manifold, to the starter, loomed all the wires, & she, Tioga (I wont call it a beast again) is running like new again.
    You folks are awesome... next trick will be turning the heat & fridge on when I get the propane tanks filled.
    Stay blessed... I need you
  • Glad you found your issue!
    You should get a new fusible link as it protects your system. Should be able to get the correct size at O'Reilly's, Auto Zone or other auto parts stores. Color designates the amperage. Beleive it should be 30 amp which I beleive is grey.
  • Well you are half way there. You need to find the reason it melted in the first place. Or did it get roasted against the hot exhaust manifold?
